За радиаторчето на парното
sumacher
За радиаторчето на парното на SKODA FABIA 2003 без клима трябвали да се сваля цялото тобло или има труг начин? Нека ако знае някои да помогне.
Removing and installing heat exchanger
Removing
– Remove the centre console → Body Work; Rep. Gr.68.
– Reduce pressure in the coolant circuit by opening the cap on the coolant reservoir.
– Use hose clamps - MP 7-602- to pinch off coolant hoses of heat exchanger (if not possible, drain coolant).
NoteIf the heat exchanger is replaced, drain the entire coolant and fill system with fresh coolant.
– Place cleaning cloth below heat exchanger connection to collect drained coolant.
– Detach coolant hoses -2- and -3-.
– Carefully blow coolant out of the heat exchanger with compressed air.
To do so connect up the hose with compressed air on the connection fitting for the feed and attach the container under the connection fittings for return flow.
– Unscrew connection fitting for heat exchanger -1--arrow- and lay to the front.
Tightening torque: 20 Nm
For vehicles with heating element for additional heating (PTC) -Z35-
– Separate plug connection of the auxiliary heating to the vehicle wiring loom on left or heater unit.
– Unscrew the earth cable of the auxiliary heating underthe bottom part of the distributor housing.
Continued for all vehicles
– Remove connecting part for rear duct -3-.
– Lever off retaining clips -1- on right, on left and at rear.
– Lower bottom part of distributor housing with heat exchanger -2- at the rear and pull out of the front catch towards the rear.
– Carefully swivel out bottom part of distributor housing to the right -arrow-.
– Take heat exchanger out of the bottom part of distributor housing.
– Carefully remove heating element for additional heating (PTC) -Z35- upwards from the bottom part of distributor housing.
Install
Installation is carried out in the reverse order. Pay attention to the following:
– Moisten sealing lips of the gasket in the bulkhead (assembly plate) and heat exchanger with a neutral soapy solution before installing the air conditioning unit (easier mounting).
– Carefully press gasket -1- in the bulkhead (assembly plate) from the outside into the groove of the connection fitting -2- of the heat exchanger -arrows-.
– Replace O-rings at connection fitting of heat exchanger.
– Connect coolant hoses the right way round.
In direction of travel
on the left: Feed
on the right: Return flow
– Inspect coolant level, top up with coolant if necessary.
