skoda-auto.bgskoda-auto.bgskoda-auto.bgskoda-auto.bgskoda-auto.bgtraxxaspepino-racing.comtraxxas
Малко тъп въпрос...
kukumitcin
Сигурно звучи тъпо ама....като не съм запознат питам ;)
Та някой би ли ми казал какво значи DOT-а на една гума?
Мерси предварително.
Това е комбинация от цифри, която показва през коя седмица на коя година е произведена гумата!
Ето и пример: 3705- 37-ма седмица на 2005г.
VooDoo
кажи мнението ти има ли някаква връзка с въпроса ми?
май не.
Само се пълнят темите така!
Извинявам се ама не се здържах.
http://content.answers.com/main/content ... recode.gif
http://content.answers.com/main/content ... ode-lt.gif
http://www.carbibles.com/tyre_bible.html
DOT Codes and the 6-year shelf life
As part of the DOT code (G above), there is a tyre manufacture date stamped on the sidewall. Take a look at yours - there will be a three- or four-digit code. This code denotes when the tyre was manufactured, and as a rule-of-thumb, you should never use tyres more than 6 years old. The rubber in tyres degrades over time, irrespective of whether the tyre is being used or not. When you get a tyre change, if you can, see if the tyre place will allow you to inspect the new tyres first. It's not uncommon for these shops to have stuff in stock which is more than 6 years old. The tyre might look brand new, but it will delaminate or have some other failure within weeks of being put on a vehicle.
Reading the code. The code is pretty simple. The three-digit code was used for tyres manufactured before 2000. So for example 1 7 8 means it was manufactured in the 17th week of 8th year of the decade. In this case it means 1988. For tyres manufactured in the 90's, the same code holds true but there is a little triangle after the DOT code. So for this example, a tyre manufactured in the 17th week of 1998 would have the code 178
After 2000, the code was switched to a 4-digit code. Same rules apply, so for example 3 0 0 3 means the tyre was manufactured in the 30th week of 2003.
DOT Age Code Calculator
The calculation built in to this page is up-to-date based on today's date. If the DOT age code on your tyres is older than this code, change your tyres.
DOT AGE CODE: 1001
Interesting note : in June 2005, Ford and GM admitted that tyres older than 6 years posed a hazard and from their 2006 model year onwards, started printing warnings to this effect in their drivers handbooks for all their vehicles.
VooDoo
май не.
:smt017 и аз не се сдържах :smt039
