VW engine on Skoda
sdandrei
I have VW RP 1.8 engine on my Skoda Rapid.
You need first a flange fixing gearbox with VW eng. from a Felicia 1.9D, also the flywheel from the same engine. (originally VW flywheel is fixed by 6 bolts to the crankschaft, in Felicia 1.6 and 1.9D is by 4 bolts)
VW have 2 cylinder block types - big and small. Small blocks are fitted in all 80's Polo (incl. G40), Jetta/Golf 1.3 as well as in the new generation 1.1, 1.4 and even some 1.6 (like Felicia). The big are old 1.6/1.6D, 1.8, 2.0, and new 1.6 (excl. Fel.1.6MPI, Polo 1.6Mi, Seat Ibica 1.6Mi), 1.8 (8 or 16V), 2.0 (8 or 16V) even G60, WR6 1.8T (20V) etc. If you are going to use a small cylinder block you have to purchase a flange for Fel1.6 and Fel1,9D to put a big block accordingly.
Me heard only about 1.6 flange. What about the power plug, the axe between the engine and gera box. Is there needed a piece or something?
I have an 1.6 golf MK1 engine. 75 HP
@Hasek: Are there any picture of your engine and detailed with the flange?
No, you just have to purchase an out-rigger bearing for the crank for Audi 80 !!! (for 1,8 fore-and-aft placed engine) and to replace it with the bush on the back side, this will enable you to fix the axe on the crank ;)
P.S. in order to fit you MK engine you'll need 1.9D flange
  • 5 месеци по-късно...
  • 2 години по-късно...
i have recently purcased a 1.8 110bhp engine from audi 80 , i start the process to munt the engine on my skoda 105 , i have purchased the flange from the skoda felcia 1.9d. Now my biggest problem is that the engine stay's about at 65degres , what do i have to do that the engine to come straight ?
Hi, 65 degrees :?: :!: :lol: You mean the engine stays almost like "boxer type"? Something doesn't fitted properly. Have a look again at the flange fixing to the gearbox. Probably you have turned it in some wrong position. Usually the engine should stay at about 10 degrees right
Regards,
